HELP! John Deere 50 power trol and hydraulics
Robert Cornell
05-30-2006 04:53:55
I posted this yesterday with no response. I am really hoping someone can help or tell me I am missing something stupid before I get into the pump.....
Ok....I know that this has been widely discussed and I have spent the last 1 1/2 hours reading messages and must still be missing something.
Last fall while mowing with the brush hog and my 50 (3 point using cultivator brackets on the rock shafts), the 3 point dropped and would not lift. After removing the weight from it, the rock shafts still would not turn. Keep in mind it was working fine. The hydraulics on the tractor have worked great for years. I ran a wood splitter as well as the lift on a #5 mower as well as the 3pt hitch. This happened suddenly, not over time. There were no leaks externally. The IT manual lists several possibilities that I have also seen repeated on this site...so....I finally broke down and removed the power trol valve, and rear rock shaft housing. I removed the piston housing (cylinder) and I installed a new o-ring and wiper on the piston (cylinder seemed fine - no scoring). I installed a new gasket re-assembled and torqued retaining cap screws to 150 ft-lbs as per the instructions. On the power trol valve assembly I cleaned the check valves and balls and cleaned the relief valve and throttle valve cleaned the whole assembly, installed a new gasket, re-assembled and tried it out..... no dice...the rock shafts would move very slowly (they wouldn"t move up at all before - so I guess there was some improvement)into the up position and would hold their position until I released the valve. I have frigged (highly technical terminology) with both the throttle valve and the valve that is supposed to increase lift speed on the side of the Power trol unit with no luck (the throttle valve does control how fast the shafts drop, so I am pretty sure it is ok.). I don"t have the equipment to check pressure as prescribed in the manual although I suppose I can get it and fab it up, so my question is --- What next? The pump? I even went so far as to install check valves, balls, springs and relief valves from another power trol unit I had lying around..... no luck and I am getting close to the wrench throwing stage.... I almost have to believe at this point that the pump is the problem....but I am hoping it is something simple that I missed. HELP!
johns48b
05-31-2006 08:36:56
 Re: HELP! John Deere 50 power trol and hydraulics in reply to Robert Cornell, 05-30-2006 04:53:55
sorry i'm not familiar with the fifty. is there any lines you can undo and see if the fluid is coming out as it should be. it sure sounds like you've just got an obstruction in the line some place. you didn't happen to add some fluid lately did you and some trash fall in by chance? good luck.
Robert Cornell
05-31-2006 09:44:44
 Re: HELP! John Deere 50 power trol and hydraulics in reply to johns48b, 05-31-2006 08:36:56
I am now just about sure the pump is the problem. lines are clear, valves seem to be functioning properly, but no pressure or flow. It seems odd that this happened suddenly, rather than a loss of pressure over time. The pump seems to engage and my IT manual only shows one internal key inside that could have sheared on the pump gears. Into the pump I go! Thanks!
Robert
Glen in TX
05-30-2006 08:06:30
A pressure test should help find if pump is doing it's job and if so then oil is leaking internal someplace else. Cylinder cup blown, cylinder gasket leaking, housing gasket leaking, internal casting crack or leak from casting hole opening up. Broken cam or linkage. Key sheared on pump shaft. The JD SM2011 Hydraulics service manual gets more in depth on hydraulics for letter and early number series Waterloo built 2 cylinders. A I&T manual should also have enough specs. to get you by.
billde
05-30-2006 05:36:19
See if you can borrow a hyd test guage, if not buy one, they aren't expensive. Plug into the remote outlet and see what you have for pressure. This will tell you if your pump is o.k.
johns48b
05-30-2006 05:27:05
i'm not good on these things but i was just curious, you didn't kick the lever off that runs the pto did you? just guessing but it sounds like something broke and you should be able to find it if you keep looking. if you don't get any help here e-mail me and i'll give you the number for a jd dealer who still has an old mechanic working for him thats good on two cylinder tractors. [email protected]
Robert Cornell
05-30-2006 05:52:33
 Re: HELP! John Deere 50 power trol and hydraulics in reply to johns48b, 05-30-2006 05:27:05
Thanks, On the 50, the pump is coupled to the governer and is not coupled through the pto. The pump does engage and as I said, the rock shafts now turn, just extremely slowly. It is almost as if the pump is not building enough pressure to overcome the checks. It just seems odd that this occurred suddenly and not over a period of time (as you would expect pressure to decrease as pump wear increases). I guess I will have to rig up something to test pump pressure. Thanks again.
MACE
05-31-2006 17:10:38
 Re: HELP! John Deere 50 power trol and hydraulics in reply to Robert Cornell, 05-30-2006 05:52:33
Did you notice a low fluid level when you drained the power trol?
Did you check for a rise in tranny fluid as well?
I can't say for sure, cause I don't own a 50 JD.
MACE
