420 John Deere
pf57jd
05-29-2006 19:24:21
I had a engine lock up because tractor was left outside for the winter & spring without the stack being covered. I filled the engine with keo. and left it for a week. The crank loosed up with very little turning of the pulley after that week. I have replaced the points, plugs, coil, & condenser. The battery and starter are in good shape. I checked all of the key points and I have spark. The engine cranks fine but it will not turn over. Any sugestions?
`Bernie in MA
05-31-2006 16:25:05
 Re: 420 John Deere in reply to pf57jd, 05-29-2006 19:24:21
Do you have spark when and where it is supposed to be? I got my plug wires mixed up once.
pf57jd
06-01-2006 04:00:57
 Re: 420 John Deere in reply to `Bernie in MA, 05-31-2006 16:25:05
I have tried switching the plug wire and it still just cranks and doesn't turn over.
Could the carb bad? I know this tractor sat for about a year with some gas in the tank.
HenryM
05-30-2006 06:15:02
Did you pull the drain plug out of the bottom of the carb and see if you get a steady stream of gas running out?
pf57jd
05-30-2006 06:59:42
 Re: 420 John Deere in reply to HenryM, 05-30-2006 06:15:02
Yes! I pulled the carb bottom plug and there is a steady stream of fuel coming out.
wkk427
05-29-2006 20:41:15
check the compression if it is low put about 1 teespoon of motor oil in cylinder if rings are stuck this will bring the compresion up and motor should crank if not you have a valve that is not seating
