50
Texas Denny
05-28-2006 21:38:06
Is the sheet metal on a 50, 520 and 530 the same except for paint? Thanks,
Glen in TX
05-29-2006 22:02:37
 Re: 50 in reply to Texas Denny, 05-28-2006 21:38:06
Hey Denny, If you know of a salvage 520 with clutch and other parts let me know. Thanks.
Texas Denny
05-30-2006 06:51:03
 Re: 50 in reply to Glen in TX, 05-29-2006 22:02:37
Haven't started to look yet. Need to get it home first. If I find one, I'll let you know. Where are you at? I live in Leander and have a ranch in Goldthwaite.
Glen in TX
05-30-2006 12:34:20
 Re: 50 in reply to Texas Denny, 05-30-2006 06:51:03
Okay, Thanks just wondered and still looking for more 520 parts too. I'm SW of Amarillo by Friona.
Texas Denny
05-30-2006 14:51:31
 Re: 50 in reply to Glen in TX, 05-30-2006 12:34:20
that's a fir piece
Carl NY
05-29-2006 11:45:33
Denny. The 530 sheet metal is definately different from the 50 & 520. The 520 nose piece can be used, the front emblem is attached diffently. If your 50 doesn"t have power steering you will not need the knock out hole to access the power steering dip stick. The hoods are a pretty clean swap.
Texas Denny
05-29-2006 20:43:59
 Re: 50 in reply to Carl NY, 05-29-2006 11:45:33
Thanks, Carl. That is what I thought (the 50 and 520 could be used). I needed the verification. I just bought a 50 and it may need the everything around the radiator. Don't know yet for sure.
Thanks again.
John T
05-29-2006 05:32:44
Yo Denny, Glad to see you over here in the land of green instead of that orange stuff lol. Why dont ya come to Indiana and fix my D 15 from jumping out of 3rd gear?? I may pull the big flat side inspection soon and see if or why the forks dont slide it over far enough into mesh.
Sorry, cant answer the sheet metal question excpet that the 30 series is different.
Ill see ya back over on the dark side if I tear into the D15
John T
Texas Denny
05-29-2006 06:22:03
 Re: 50 in reply to John T, 05-29-2006 05:32:44
Just bought a 50 that needs some sheet metal. Haven't even seen it yet other than a couple of pictures (low res at that).
The 15 trans should be a challenge. I thought we were going to get at it before the season. Now the down time will hurt. This sounds a bit odd but, in a way, I'm looking forward to this effort. I believe it is a design flaw that shows up because of poor manufacturing tolerances. The folks on the Allis board mostly disagree with me though a couple share similar experience.
Glen in TX
05-28-2006 21:51:43
530 sheet metal will be different but not sure if any alike between other two.
