730 diesel doesn't want to run
730virgil
05-28-2006 20:52:52
i have had this happen before tractor will start but not speed up or run . half tank of fuel, fuel turned on at tank ( turn it off every time as otherwise it leaks ) last time i had this happen i ended up changing fuel filters and bleeding lines which i plan to do tomorrow . any ideas why this keeps happening ?
730virgil
05-30-2006 19:07:32
 Re: 730 diesel doesn't want to run in reply to 730virgil, 05-28-2006 20:52:52
that's what i afraid of transfer pump is what's leaking . is going to cost some money to fix this
johns48b
05-29-2006 05:18:49
you solved your own problem by saying you had a fuel leak. fix that leak and you'l stop sucking air into the fuel. be sure all the fittings on your diesel fuel lines are all snug.
