Do I have the only Air Cooled JD 620 ever made?
Steven Mack
05-28-2006 14:45:49
Now don't you fools try telling me this tractor deoes not exist causeI know it deos.I own it and have a very deep knowledge of things green and yellow(I'm I Bleed Green,JD 4020 gas).Anybody else have one?How much is it worth?
Glen in TX
05-29-2006 22:06:44
 Re: Do I have the only Air Cooled JD 620 ever made in reply to Steven Mack, 05-28-2006 14:45:49
If someone put one of those 60 HP Wisconsins in it and the crankshaft isn't broke yet it will be soon. Got more in the other day with broke crankshaft if someone needs a parts engine.
buickanddeere
05-29-2006 17:38:55
Everyone once and a while some cheap hack will pull the block & head from a two cylinder. Then bolt some other engine between the frame rails and belt it to the flywheel. All told the cheap,easy fix costs more in time and money than a proper repair. And it renders the valuetractor to junk price. I suggest finding who ever made the conversion and kick them numerous times.
2-Stroker
05-29-2006 08:17:19
Do you have a picture? I know that out neighbor could run his 620 without the water pump going, and still keep it fairly cool, but I've never heard of an air-cooled 620. Does it actually have the original 620 engine in it (plus necessary modifications, of course)? Could it have been a factory experimental or what you could call a "dealer-experimental"? Maybe try asking the guys at Two-cylinder, they might have a better idea.
Good luck on your info hunt.
2-Stroker
Formerly Specter
steve from mo - dangit!
05-29-2006 05:05:26
 Couple hundred $$. Most everyone here has one. in reply to Steven Mack, 05-28-2006 14:45:49
Sheesh. What a maroon!
maroon
05-29-2006 09:40:35
 Re: Couple hundred $$. Most everyone here has one. in reply to steve from mo - dangit!, 05-29-2006 05:05:26
maroon is a color. maybe you mean moron.
I Bleed Green
05-29-2006 08:38:50
Yep! Maroon, that what we have here. I'll bet i know who it is too.
I Bleed Green
05-28-2006 15:02:54
I will have Kim taking this off soon, and i hope she bans this SOB as well.
jdhbag
05-28-2006 14:55:34
Show us a picture.
