Engine manuals
CFWelles
05-28-2006 06:30:35
I recently acquired a service manual binder which was what I wanted. The binder has three engine service manuals in it. First is the GM 2-53 diesel engine. Manual shows this blower equipped engine fitted in a 440 dozer. Isn't this the same motor that is used in a 435? Other two are a Hercules QXD-3 (SM-2012) and a 92, 145, and 217 power unit manual (SM 2026). Is there any broad application of these latter two. Looks like the SM-2-26 has strickly industrial application for pumps, generators, and various fixed installations?
Glen in TX
05-28-2006 09:59:27
 Re: Engine manuals in reply to CFWelles, 05-28-2006 06:30:35
Hercules QXD-3 engines were used in 55 SP combines and 217 in 95 SP combines.
CFWelles
05-29-2006 05:03:39
 Re: Engine manuals in reply to Glen in TX, 05-28-2006 09:59:27
Thanks Glenn. Your answer is on the applications that would take a little more work. Not receiving comments on the diesel, made me realize that the answers to this engine are right here on this board and I should be doing my own review and search instead of asking for experience to be coughed up from readers here who know the 435 and its power plant backwards and forwards. Doing a quick look, I see that the GM 2-53 two stroke in the 440 crawler is apparently identical to the one in the 435. One post mentions that entire drive train is the same (except pto ?). If anyone knows of any differences between these two engines in these two different JD applications, I would appreciate their comments. Thanks again Glenn for the applications for the two gas engines.
Glen in TX
05-29-2006 08:46:41
 Re: Engine manuals in reply to CFWelles, 05-29-2006 05:03:39
CF, Yes the 2-53 was called 106 cu. inch and used in both as you discovered and the 440 also used the 113 cu.inch gas engine also that other 420 & 430 used. Not sure what the 92 or 145 were used on? Pumps, windrowers, SP sprayers, balers? Can't believe your engine service manual didn't have a specs. & application page inside? I have a SM2080 service manual for power units 135,152,180,202, & 303. It has specs. & applications pages for combines using the larger engines and smaller engines in windrowers and hi-cycle sprayers. Anyway some of the JD service manuals like this SM2080 have a wealth of information that would answer many questions you see on this board as manual has extensive coverage not only on engine overhaul but also on overhaul, repairs and testing of carburetors, distributors, generators, alternators, and starters. The general info in some of these manuals applies to many other engines as well so they are worth the time and money to obtain.
