John Deere 520 Clutch
Dave Irish
11-30-1999 06:25:08
The fixed drive clutch disk that is splined to the crankshaft was not tightened properly by the previous owner and the spline on the crankshaft is worn and loose where the disk attaches to the crank. Does any one know of a method to repair the splines so that it can be tightened properly, or does one jsut replace the crankshaft.
Jim
11-30-1999 07:40:18
 Re: John Deere 520 Clutch in reply to Dave Irish, 11-30-1999 06:25:08
I have never done a 520,but did an A and a 60.
All we do is coat the splines with JB weld and put the counter wieght on and tighten it up then let the JB weld set up for a couple of days and it is fixed.If you want it off heat it up and the JB weld will let go.
Doofus
11-30-1999 06:40:15
It has been done many times with a welder and a die grinder. Just weld up the worn down splines, then carfully grind and file until the driving disc fits (best off to use a new driving disc). Knit picky perfectionists might have a cow over this, but it works well, and is faster and cheaper than removing the whole crank and replacing it or having a machine shop respline the crank.
