Fasse Valve and John Deere 3020 with positive grou
Darren T. Schin
05-27-2006 08:30:39
Hello all!!! My father and I are in desperate need of some help. He has recently purchased a Fasse remote valve controller. His 3020 is a positive ground (being an electrical engineer, this is totally confusing me). The Fasse Valve kit he originally got was for a negative ground and of course it didn't work. He ordered positive ground solenoids and it still doen'st work. I have the ground going to the fuse on the panel underneath the steering wheel and the positive going through the fuse to the fender. When we don't have the solenoids hooked up, the controller box works fine, but as soon as we install the positive ground solenoids it stops working!!! Any ideas!!! We have hay down and we can't round bale it.
Thanks!!!
Bob
05-27-2006 13:15:24
 Re: Fasse Valve and John Deere 3020 with positive in reply to Darren T. Schindel, 05-27-2006 08:30:39
Why does polarity matter to the solenoid valves? Do they have a diode connected across the coils to reduce arcing at the switches?
Is this a gasser set up 12-Volt (+) ground, or a diesel, which is 24-Volt?
If it is a 24-Volt diesel, the fuse or jumper wire connecting the middle of the series-connected 12-volt batteries to chassis ground mist be in place, or you'll have all kinds of problems getting (+) 12-Volts, or (-) 12-Volts to function.
jddriver
05-27-2006 09:32:58
Gas or diesel?Should have two 12v batts if diesel and two 6v if gas.Should be neg grd.You might be tying into the jumper cable going to other battery.Steve
Darren T. Schindel
05-27-2006 19:40:49
 Re: Fasse Valve and John Deere 3020 with positive in reply to jddriver, 05-27-2006 09:32:58
Thanks for replying. It's is a gas with 12 postive ground. My dad got it working today. He had to run a wire from the top nut on the solenoids to the tractor chassis for a better ground.
Yes, the postive solenoid has a diode in it (cathode on wire where controller is attached) and the other doesn't. The only thing I can think of is that is hydraulics didn't have a good ground on it.
