How to pull the pistons liners from Detroit 2-53?
slimjim
05-26-2006 19:08:20
Engine is set up, need to pull pistons and liners. Engine is unable to get to TDC.
Thanks,
Dee
johns48b
05-27-2006 05:14:19
 Re: How to pull the pistons liners from Detroit 2 in reply to slimjim, 05-26-2006 19:08:20
take your new liner to a machine shop and have then machine a thick block (1/2 or more) down to fit the outside diameter of the piston and then come 1/4 inch or so down with a step in the block that will fit inside the sleeve real tight. bore a hole in the center of the block that will let a chain slide down through. drop the chain in the hole and put a bolt through it. loop the other end of the chain around a 1 inch or bigger steel bar. rest the steel bar on one end on a hydraulic jack and build blocks under the other end of the bar to equal (or slightly higher) the height of the jack. jack away and your liner should come out. i have had to take a punch and chiesel and break the sides off of the liners a piece at a time to get them out. some other guys probably have some better ideas than this, but i know this works. lol
buickanddeere
05-26-2006 22:04:23
New N pistons and liners are dirt cheap and the old low compression S units are junk even when they were new. Just don't bust the block. Check for coolant passage cracks at the front left block heater port.
lisat
05-28-2006 11:15:35
 Re: How to pull the pistons liners from Detroit 2 in reply to buickanddeere, 05-26-2006 22:04:23
what is the best place to pickup a waterpump for the 435 2-53 or rebuild ?
buickanddeere
05-29-2006 17:48:12
 Re: How to pull the pistons liners from Detroit 2 in reply to lisat, 05-28-2006 11:15:35
Napa or any other jobber shop. You will get a blank look after asking for a JD 435's 2-53. Try asking for a water pump for a 3-53 or 4-53.
