1937 JD water in oil-advice
Mike in Wi.
05-25-2006 19:20:05
Need your help here guys.Bought a 1937 John Deere A.Had water in oil and oil in water.First thing I thought was cracked head or gasket,or valve guide tubes.Had the head pressre tested at machine shop and every thing was good.Do not see any cracks in block.I do know the tractor had sat for a long time.Any ideas where to go from here?Thanks
DSK
05-25-2006 20:26:39
 Re: 1937 JD water in oil-advice in reply to Mike in Wi., 05-25-2006 19:20:05
You didn't say what the head gasket looked like so I assume it's OK. You said you were also getting oil in the water. This would suggest that your pushrod sleeves are leaking as the unstyled A's had no internal oil passages under pressure in the block or head. Even though they might look good on the inside. you can bet they are badly corroded and possibly pinholed on the water side. Have the head magnafluxed for cracks including inside the ports and valve seat area. Check the block carefully around the studs,cracks in this area are common.
