720D Power steering fluid
NYChas
05-25-2006 15:54:53
Have a chance to work on my 720D and the dealer That will be near me doesn"t have the old style power steering fluid.I was wondering if there is any substitute. Thanks Charles
Dan in Ohio
05-27-2006 07:08:12
 Re: 720D Power steering fluid in reply to NYChas, 05-25-2006 15:54:53
NYChas, Next time you go to your JD dealer and they tell you they do not carry something ask them to do a dealer search and tell you where the nearest JD dealer that does carry the product is located. When they see you leave money in hand you will have made your point. I have 8 old JD's and I rarely get turned away from my local dealer (Shearer Equip.)
DSK
05-25-2006 20:08:38
Iwould wait until you get the proper oil. These systems are very fussy about what kind of oil will work in them. Why contaminate the system with the wrong oil only to drain it out in a few days? Also, these systems do not take kindly to flushing, you can score the walls of the steering cylinder because most flushing agents do not have enough lubricant value when pushed through it at 1500 PSI. It is also impossible to get system completely empty without complete disassembly.
55 50
05-25-2006 17:03:26
Has it been discontinued? Or maybe the dealer just doesn"t want to carry it. I got some from John Deere about two years ago.
NYChas
05-25-2006 17:07:37
 Re: 720D Power steering fluid in reply to 55 50, 05-25-2006 17:03:26
The dealer can get it but won't have any this weekend.Just looking for a substitute to get me going.
720Deere
05-25-2006 18:21:03
 Re: 720D Power steering fluid in reply to NYChas, 05-25-2006 17:07:37
For the short term, ATF will work just fine. I have used it with now discernable problems. I have also used 10W motor oil. I have not used it but heard of people using HyGuard oil as well.
Basically any lightweight oil will likely work for the short term, but when the 2 cyl PS oil is available, I would flush the system and use it permanently.
