Hood and grille mounting questions ?
wddave
05-25-2006 14:25:21
I ordered item 17 on the hood parts breakdown and got a length of fabric belting. Where does it go and what does it do? Also the bushings or spacers that go into the rubber pads for mounting to the radiator have a machined profile on one end. What is the purpose of that?
Thanks,
David
http://www.jdheritage.org/retiredtractors/PC330/61-Hoods.html
CalJim
05-25-2006 22:42:20
 Re: Hood and grille mounting questions ? in reply to wddave, 05-25-2006 14:25:21
Hello,
The Canvas type webbing strap is to be adhered to the underside of the nose cone. Simply cut and glue a piece in, it functions as a pad between the nose cone and hood. CalJim
wddavd
05-25-2006 20:07:14
The tractor is a 1945 model about 168,000. If the belting is used on the early models only that makes sense since there doesn't appear to be place for it on the this one. It don't have a parts book and the parts breakdown at the dealer looked just like the one on the jdheritage web site. Thanks,
David
johns48b
05-25-2006 18:39:01
if memory serves me correctly that fabric went in between the hood and the two grill halves. i happened to have a piece of wide nylon webbing that i put in mine and just barely let it stick out between the parts. its been there 6 years now.
B-maniac
05-25-2006 17:07:32
You can make all your own "insulators" as I call them.Anyplace painted sheet metal overlaps other metal parts.There are a lot of materials out there that work well for this. Also,it works well and doesn't show,to use paper thin nylon or fiber washers on the fasteners that are used to hold sheet metal parts on or together.Save your paint! The factories didn't place a very high priority on thisback then and it showed up real quickly.You can be 100% factory correct OR you can be smart....
P Browning
05-25-2006 16:30:44
wddave -- I assume you are referring to page 61 of the PC330 Parts Catalog for a Styled JD B tractor. Item # 17 applies only to B's built in 1939 & 1940 while the other items you mention (rubber & steel spacers, items 5 & 6) apply to B's 1942 & up. They are mutually exclusive on any given tractor! Note also that the hood for the early styled B is different that one for 1942 & up, and the interface between hood and grille pieces may be part of this delta.
Your question is difficult to respond to without knowing the year or s/n of your tractor. However, be advised the use of pads between sheet metal parts is to provide a "cushioned fit" thus reducing loss of paint at points where sheet metal parts meet.
More often than not, restorers end up fabricating many of these pads from raw material stock rather than trying to buy them. I am surprised Deere was able to furnish the fabric belting you referred to. (PatB)
