148 4020 odd hydraulic situation question
Nylon
05-24-2006 21:35:19
I have a joystick on my 148 loader. I have a new and odd developement. If I shut off the tractor with bucket and loader up, they will not bleed down and inch in a week since I put new seals in everything last winter. The weird thing is that when the tractor is running the bucket will start to drop or bleed down...the loader wont...only the bucket and only when running with a load or with no load. Any ideas?
Tx Jim
05-25-2006 03:59:35
 Re: 148 4020 odd hydraulic situation question in reply to Nylon, 05-24-2006 21:35:19
Nylon,I'll take a guess. I think since bucket stays put without engine running but leaks off with engine running that your spool valve leaks internally under 2250 psi supplied from hyd, pump. If this is correct the only solution is a new valve as most spool valves are non-repairable. Tx Jim
nylon
05-25-2006 10:27:09
 Re: 148 4020 odd hydraulic situation question in reply to Tx Jim, 05-25-2006 03:59:35
thx txjim. That is what I was thinking too but it is a pretty new valve. Looking for a consensus.
Mike M
05-25-2006 10:55:13
 Re: 148 4020 odd hydraulic situation question in reply to nylon, 05-25-2006 10:27:09
Pretty new or brand new ? but either way I suppose you could of gotten a bad one. Alot of these NEW valves aren't built very good as the quailty of overseas stuff is iffy.
I used an old valve from a JD industrial tractor loader a model 500 I was lucky to get it as these are very good valves.
I think you could always add a load check valve in line. Grabbed the Northern Tool catalog and it looks like item # 2070-1605 at $74.99 may be what you need ? I have never hooked up one of these ,but have heard about them. Only I suppose that if it operates by pressure and since you are closed center system and you may be leaking pressure than maybe ? it could acuate this valve from the leakoff being pressureized ? I have no clue for sure I guess it'll cost $74.99 to learn for sure ?
