2010 jd split
dennis paulson
05-24-2006 12:35:53
I split my 2010 roe crop to replace the clutch assembly and ground the flywheel. Now I am 3/4 inch away from going back together. Is there an alignment tool for these like a car?? I assume I am not lining up with the pilot bearing is there a trick?? Do I have to line up the clutch plate differently?? Thanks for any advice you may have!!!!
dennis paulson
05-30-2006 12:36:12
 Re: 2010 jd split in reply to dennis paulson, 05-24-2006 12:35:53
I got my tractor slid back together, learned a trick. I left the six bolts holding the presssure plate in,loose about 1/2 inch,so the clutch plate could float around. Then I tightened them after I slid it back together thru the access hole on the bottom of the tractor. But now am wondering if I can Adjust the three locked bolts on the pressure plate for the clutch fingers thru this access hole, Looking for a little more pedal adjustment,I am maxed out on the camm by the brake pedal. has anyone tried this?? THanks
johns48b
05-24-2006 13:53:30
i feel for you. on trucks and tractors that i put clutches in i try to turn the end of the trans shaft where one groove in it is close to alighment with the slots in the clutch disk. once i get it close i put some longer bolts in it on each side to help align everything up and then push the clutch in and take some of the pressure off of the clutch disk. that way it will help self center its self up. don't use those longer bolts to pull it up with or you'll ruin something. when its right it will slide together. most of the time the problem comes from the two halves not being aligned in the vertical direction so check out the space at the top and bottom and get them as close together as you can and it should go. good luck. i'll loan you a few choice words if you run out of ones you know.
dpaulson
05-24-2006 15:24:14
 Re: 2010 jd split in reply to johns48b, 05-24-2006 13:53:30
Thanks for the advice I'll give it another try, I did not think of pushing the clutch pedal in.
