JD A transmission noise
john dear
05-23-2006 21:07:17
52 JD A growls pretty bad in all gears under load. Growl is basically the same regardless of gear and gets worse with load. I am guessing it is a bearing or twelve with rust damage. Since it is the same in all gears it must be a bearing that runs at engine RPM and is under load in all gears. Any idea where to look first?
Thanks,
johndear
05-24-2006 19:55:24
 Re: JD A transmission noise in reply to john dear, 05-23-2006 21:07:17
Thanks for the thoughts. Probably be worth the trouble to slip the outer first reduction bearing off and replace it and see what happens. Figured it was the fresh paint making it noisey! Bad thing about painting one before you get to chance to find all the problems.
JD A
05-24-2006 18:03:39
It aint that bad I had one of those rascals go out and let the shaft drop were I could not go from the right side of the shift patteren to the left in my 50' A. We went ahead and replaced all six bearings. The only bad part was they were close to 400 bucks.
2cylinderlp
05-23-2006 22:24:12
If it is noisy while pulling but quiet when coasting (in all gears), it might be the primary reduction gear and the clutch pulley gear. I have a southern high time tractor, and it makes noise like you describe. The gear teeth are worn flat on the pulling side and that makes them noisy.
Pappy
05-23-2006 21:38:36
Try the easy thing first. Pull the cover off the side of the reduction gear cover and see if the small bearing is shot. You might be able to replace it without too much trouble. It could cause this problem. Otherwise, you have to open her up for major surgery.
