47 A looses power
grandads A
05-23-2006 16:15:55
I have a 47 A that seems to run just fine when just driving around, but whenever I put a load on it, it starts to lose power in just a short time. I have been trying to pull a 12 ft tandom disk, when i first start it will pull easily in second gear but after a pass or two accross the field she will loose power and then die. This has happend to me twice now, would love any help you culd give.
johns48b
05-23-2006 19:07:37
 Re: 47 A looses power in reply to grandads A, 05-23-2006 16:15:55
i've heard other guys make post about being sure the is no restriction in the air flow coming to the carb too. leave the tube off going to front of carb and see what happens. any time i ever had a engine run, get hot and die it was always the coil. you could let it cool off real good and it would crank back up.
grandads A
05-23-2006 19:00:08
The sediment bowl is clean and so is the carb screen, have a good flow of fuel getting to the carb. I can run all day long with little to no load might go 15-20 minutes under load befor it acts up. Just put a new temp guage on and I am getting just over 160 for the temp.
Glen in TX
05-23-2006 18:43:10
Carry a spare wire and plug with you and when it dies check for a hot blue spark. If no spark you can suspect a bad coil, condenser or even wiring. Heat expands things and makes wire and foil inside grow apart and insulation cracks causing a failure yet it will start again when cold and insides have contracted and being insulated again. If it's not ignition when it cools off check for a steady flow of fuel at carburetor letting it drain in a can for a minute or more watching for a steady stream. Could have crud in tank or carb need cleaning and rebuild. Did you try opening the load needle more or changing carb settings?
DSK
05-23-2006 18:32:44
Could be any number of things. If the tractor has a magneto,(most likely Wico) have it tested and rebuilt if needed by someone who knows what they're doing. If it has a distributor, have the coil tested at an automotive machine shop. Is the fuel tank & sediment bowl screen clean? There is also a screen in the carb under the fuel inlet chamber cover. Does the heat gauge work and if so, how warm does it get? You didn't say how long it runs good, 5 minutes? 20 minutes? Itsounds like something fairly simple.
