520 pto clunk
Ferd
05-22-2006 16:30:41
When I have the chipper running on my 520 and back off on the throttle (usually standing in front of the pulley) I hear a "clunking" noise that seems to be comming from the transmission. Is this anything to be concerned about? The first reduction gear cover has a leak and, it may be just my imagination, but it seems much worse when the pto has been used. Was going to change the gasket but had a puller (on the clutch drive) pulled so tight that I thought something was going to break. It didn't budge. Appreciate any help or advice.
Ferd
05-23-2006 14:03:36
 Re: 520 pto clunk in reply to Ferd, 05-22-2006 16:30:41
Thanks, everyone, for a lot of good information! Ferd
2cylinderlp
05-23-2006 20:29:08
 Re: 520 pto clunk in reply to Ferd, 05-23-2006 14:03:36
When you figure it out, can you post a followup? I'd like to hear what you find.
Kurt_JDB
05-23-2006 09:05:41
Could possibly be that the first reduction gear has come loose from the splined input shaft to the transmission. This happened on my "51 B. At low RPM I could hear a distinct knocking everytime number one cylinder fired. This was the gear hitting the cover. Could be causing your leak to get worse. Not sure why it came loose, but it may have been from a input shaft bearing failure.
The bearing that holds the input shaft is located in the first reduction gear cover under a small access plate. If this is the same on your tractor, you could check out the bearing by removing this cover. Also, when you get your clutch off, reach inside the cover and grab the first reduction gear, and see if you can wiggle it around.
I ended up having to replace both my first reduction gear, and the input shaft/gear because they had been damaged due to the knocking around.
Good luck.
Kurt
2cylinderlp
05-22-2006 19:38:32
I think I would be concerned until it could be determined exactly what the cause is. Chippers ususally have a large flywheel which and have a lot of angular momentum when they are spinning. It sounds like something in that pto drive doesn't like the flywheel effect of the chipper when you idle down. Maybe an over-running clutch on the PTO would get it to stop? How big is your chipper? I have a Valby that can handle up to 6" logs. I never put stuff that size through it because around here we call that firewood. I run it on a 630 and I don't have any problem at all. Does the clunk noise occur randomly, or does it occur at a repeatedly, like every time the pto shaft makes a revolution?
Ferd
05-22-2006 20:18:10
 Re: 520 pto clunk in reply to 2cylinderlp, 05-22-2006 19:38:32
Only hear it when you cut the throttle.
2cylinderlp
05-23-2006 07:51:25
 Re: 520 pto clunk in reply to Ferd, 05-22-2006 20:18:10
There may be excessive play in the PTO drive line caused by wear in the splined shafts inside the transmission (probably not likely). Or there may be excessive backlash in the bevel gears. Or it may be that you'll get that noise with just normal backlash. Either way, for your particular setup, there must be enough play in the PTO drive line to get a clunk noise when that big chipper flywheel has to suddenly slow down to what the engine speed is at. It sounds like stress on parts that you could eliminate either by very carefully throttling back, or by using an overrunning clutch.
machinery-man
05-22-2006 16:34:38
I had several 520"s and they did the same thing, you are getting some backlash from the power stroke....best to keep engine reved up...you might want to check angle of the pto shaft as this will cause a telegraphing of noise...also be sure you get good thread dept with you puller bolts, tighten up then rap end of puller with hammer...that drive will come off..
Ferd
05-22-2006 20:20:35
 Re: 520 pto clunk in reply to machinery-man, 05-22-2006 16:34:38
I was kind of thinking that hitting the end of the crankshaft like that might not be a good idea. Maybe it won't hurt anything?
2cylinderlp
05-23-2006 07:38:58
 Re: 520 pto clunk in reply to Ferd, 05-22-2006 20:20:35
On that drive disk, if you have the puller tightened up as much as you dare, try just leaving it sit under tension that way for a day. Take your time with it. When you happen to be near by give it a whack and see if the puller can be turned a little more. You'll get it off eventually.
Mike M
05-23-2006 04:45:22
That's the only way you will pull something off a tapered shaft is to put pressure on it and then give it a shock with a hammer.
