1948 A platform help needed
yooperdeere
05-22-2006 15:48:52
I was wonderin if anyone has ideas on how to get the platform off of a 48 A? The screws that hold it on on mine look rusted to the platfrom and look to be quite a task to get off. I hate to even tackle it until i can get some advice. Thanks.
johns48b
05-23-2006 05:16:38
 Re: 1948 A platform help needed in reply to yooperdeere, 05-22-2006 15:48:52
hey guys does the bolt holes go all the way through into the rear end? mine did on my 48 b. so when i put them back on i used some gasket making silicone to coat the threads with to keep any future water from getting down into the rear end. i have a impact wrench that you can put different tips on the end and hit the other end with a hammer that works real good on bolts like these. i believe i'd heat these first and let cool and the use this type impact wrench. i got my at sears, but most auto repair parts stores carry them.
Todd Wiscal
05-22-2006 22:00:06
I've set a large nut, maybe 9/16" or so, on top of the head of the platform bolt, cranked up the heat and plug welded them to the top of the bolt. The heat from welding helped loosen them and they turned out easy.
matthies
05-22-2006 20:13:56
I just removed a platform off of a 60 by heating the heads of the bolts red hot and using a impact driver to remove them. Might have just got lucky. chris
RedJD
05-22-2006 16:54:28
I had to drill mine out and retap to the next larger size.
F-I-T
05-22-2006 18:39:40
 Re: 1948 A platform help needed in reply to RedJD, 05-22-2006 16:54:28
A couple of times, I center-punched in the middle of the slot, drilled with 1/8, then up and up and up, only drilling deep enough to gnaw the top of the bevel head off, until the platform popped loose, leaving me with stubs that I could weld nuts to. A little heat in the area, and the use of the welded on nuts brought them out. It's also a nice place to use a Heli-coil or Keensert if you want to bring the size back to original if you have to drill them out all the way into the case.
Frank
