1939 B transmission question
Ted Dixon
05-22-2006 15:15:12
Have a 1939 B with a wrecked transmission that I'm repairing. I have 1941 service manuals and parts books but this countershaft is different.(No Nut on end). I know that is correct but which way does the first speed countershaft gear hub face?(B329R). Countershaft is (B321R). This is the only gear on the shaft with a raised hub on it. 1941 book shows hub faces in towards the splines, but when I removed it the hub was facing out toward the left hand bearing. Any input greatly appreciated.
Bob Collins
05-22-2006 18:03:04
 Re: 1939 B transmission question in reply to Ted Dixon, 05-22-2006 15:15:12
The gear was properly installed the way you removed it, with the hub facing out. If you put it the other way it will contact the side of the case. The "B" manual starts at 96000 with the 6 speed trans so you kind of have to pay close attention at disassembly and use good judgement. Check the archives for a picture of this very thing.
