1942 ? JD AR whats it worth?
Bob Rosloot
05-22-2006 13:33:07
I have what I think is a 1942 unstyled John Deere AR that is unrestored and in fair shape. The serial # is 261748. It was running very recently with good oil pressure. While I was getting it ready for sale, it suddenly lost oil pressure, which I didn�t notice right away. The tractor started rattling so I shut it down and searched for the problem. I opened up the crankcase and found #2 connecting rod had ripped the babbitt out of the rod and had about 1/16 inch of play now. I opened up #1 and it is not too bad, the crank looks ok but has a little wear showing. Everything else on the tractor works well and if I had the time I would probably fix it myself before selling but I have too many projects on the go already. What do you think I could get for it as is?
JD@Antique Acres
05-22-2006 13:40:56
 Re: 1942 ? JD AR whats it worth? in reply to Bob Rosloot, 05-22-2006 13:33:07
I bought a 43 AR a year ago non running but loose with all new sheet metal for $1400 I have since had it running. Just passing this along as information. Joel
