720 Diesel Teardown possible rebuild
Tyler-MO
05-22-2006 13:09:38
third party image
I'm in the process of tearing down a 720 diesel that I just bought and since it's my first diesel I thought that I'd ask for any advice and or preferences with several things like:
Pistons & Engine Components
If I have to bore it how far should I go?? .045/ .090?
Fuel Injection pump/Injectors service
Camshaft (to grind or not)
Any suggestions would be great.
The tractor will be used on dad's farm so it doesn't have to pull the tires off, but only run great and be efficient.
Check out my website link for pictures.
Mike M
05-24-2006 05:09:37
 Re: 720 Diesel Teardown possible rebuild in reply to Tyler-MO, 05-22-2006 13:09:38
I didn't see the link to more pictures the first time. Dah ! Now this makes more sense. You got your work cut out for you !
Now post a picture of after the tear down at the end of the day so we can see how much dirt and grease got on that bright white shirt. LOL !
buickanddeere
05-23-2006 15:01:03
Those timing gears look familiar. My 70D has ate one set and almost a 2nd set. There is an updated timing gear bearing setup used on the later 720/730's. The JD service bulletins has a section on oversize reamers, oversize bearing housings and staking the bearing down via drilling and tapping. Then making certain the whole thing stays put via the timing cover pressing on the end of the bearing's shaft.
GPULLER
05-23-2006 08:30:12
Tyler
I would suggest that you only bore to what is needed. When I O/H'd mine I looked around and found a good set of used .045 over Deere pistons. Much cheaper than a new set. Also, it might be possible and cheaper to sleeve back to stock and use your pistons if they are good. I also sent the cam to Berry cams in Lester Prairie MN. At fist I wasn't going to but after having it tore apart that far why not. After I got it pulled it was clear that it needed to be ground. Looking at your pictures there is no question that the cam needs to be ground.
For the fuel system work I sent my pumps and injectors to Gpower, Garry Power. Mine are calibrated to deliver a bit more fuel than stock but Garry can do stock stuff too.
Mike M
05-23-2006 06:17:22
I would only bore out to the next closest oversize that way your block can still be done bigger in the future if ever needed.
Be prepared to SPEND BIG BUCKS $$$$$$ and do it right. Enough spare cash to buy a good running 4020 should do it. Get the factory JD parts and service manuals they will guide you through it. The power steering and the custom power-trol are in seperate books you will need those if get into those areas. These 2 cyl. diesels are masters at mixing oils where they don't belong and the abilty to run with alot of problems that would stop most anything else. I just like to do a 100% complete tear down on them and fix all the problems one time and be done with them. Most people won't do all that, but if you get into the crank area go ahead and do the tranny too as you have the side covers off and are right there. Get a back brace and an engine hoist as those parts are HEAVY !
Tyler-MO
05-23-2006 07:45:39
 Re: 720 Diesel Teardown possible rebuild in reply to Mike M, 05-23-2006 06:17:22
Thanks for the heads up.
I've been through a 520Lp and spent way too much $$ on it so I know about the financial part.
I've got the SM for the 720, powertrol and for the power steering so I'm in good shape there. I think that I even have the sm for diesel engines/ or injection systems but probably won't need it as I'm going to send off the injectors and pumps for calibration by professionals.
We already have a 1968 4020 diesel so and I know that it will hands down smoke any 720 diesel....but it's just not the same.
I have an overhead hoist and engine hoist so I should be in good shape.
I've done some investigation and found the prices of injection work to be pricey!! Do you have any suggestions. I may be able to get my local diesel shop to work on the injectors themselves...but I suppose that the pumps will have to be done by someone with a test stand??
Tyler in Missouri
Mike M
05-23-2006 09:26:01
 Re: 720 Diesel Teardown possible rebuild in reply to Tyler-MO, 05-23-2006 07:45:39
Make sure you send those pumps and injectors to someone who has worked on alot of them before.Most
pump shops don't know alot about them. TWO CYLINDER and green mag. have many advertisers you can check out. If you get a set back and the injectors aren't tagged #1 and #2 to match up to each pump then you may of used the wrong shop. If you go clear through one then buying NEW injector lines may be a real good investment against one cracking and diluting your oil and ruining a fresh engine. I'm sorry, but no matter how long I stare at that picture I still can't see how the other fellow can know how your cam needs reground ?????
jhill
05-23-2006 04:30:11
Looks like a good project. I have one sitting in my shed waiting for the funds to get it going again.
I like that front weight bracket.
buickanddeere
05-23-2006 08:09:01
 Re: 720 Diesel Teardown possible rebuild in reply to jhill , 05-23-2006 04:30:11
The price will get even higher if the local diesel injection tinker shop touches more than the injectors them selves. If the injection pumps or fuel transfer pump requires service. It's time to crate it up and send them to Albert. A freshened can and followers is a wise idea. Roberts Carb among others will clean them up. If the tractor is running ok and the crankendplay is 10 thou =or-2 thou without a loose flywheel. Just have the injectors tested, put new grade 8 flywheel bolts/nuts in it and put the tractor to work.
