35 B Hand Crank
Jak
05-22-2006 10:15:18
I cleaned the carb(it has been repaired on the stem)on the 35 B but the idle screw isn't too sensitive and it takes about 4 pulls of the flywheel at full choke to get her to kick off.The customer wants it to hit right off with ease and I don't know if it will ever be that easy w/o another carb.The rockers make some noise so I was going to set the lash.Will exessive valve lash have anything to do with this or am just wishful thinking?It has nice fire and good compression but it just seems it isn't pulling the gas quick enough.What is the right DLTX # for a 1935 4 bolt B?Thanks for any info guys.
Mike M
05-22-2006 12:02:41
 Re: 35 B Hand Crank in reply to Jak, 05-22-2006 10:15:18
Every single tractor is different !!!!
4 pulls isn't bad ! Get ahold of another carb and try it you never know until you try. Any B carb. should be fine for a trial.
Jak
05-22-2006 13:41:27
 Re: 35 B Hand Crank in reply to Mike M, 05-22-2006 12:02:41
Right you are Mike,they are different.The owner has seen some start with a gentle tug and wants this one to start like that.I have worked on the carb,checked the timing,checked the spark,fuel flow,cranked it probably 20-25 times,rode it all over the neighborhood and ran it for hours and that seems to be all I can get from it with what I got to work with.I am getting it back to work on this week,I just hope there is somthing I am missing.I haven't checked for air leaks yet but will when she gets back to my shop.There is no pet cocks on this B either making it harder to turn over.Thanks guys.
Bguy
05-22-2006 10:30:54
Jak, Based on what you are saying, the first thing I would look for would be a worn carb. shaft and/or the manifold to see if they were leaking air. The 35 B"s came with a DLTX 10 carb.
