710 JD
MarkSSM
05-22-2006 08:14:08
Could someone answer me as to how the clutch on a 710 JD tractor disengages the PTO?
The PTO will not stop turning if I push the clutch half way or all the way down.
R. John Johnson
05-23-2006 05:43:26
 Re: 710 JD in reply to MarkSSM, 05-22-2006 08:14:08
Mike
To stop the pto from turning, the clutch must be pressed down as far as it will go. There is an adjustment bolt on the left side of the front part of the external linkage that will allow you more travel on the clutch if the second stage is not releasing. The PTO will always freewheel some, even when shifted to neutral and is nothing to be worried about. If you can't get it to quit turning under load, then you have a problem. I had the clutches done on our 510's this winter. One clutch was a snap, simply replaced the facings and away it went. The second clutch had other parts also worn and parts were not available from the rebuilders supplier or mother Deere. I had to buy a half wore out clutch from a wrecker and build one out of the two.
John
MarkSSM
05-23-2006 07:48:34
 Re: 710 JD in reply to R. John Johnson, 05-23-2006 05:43:26
Thanks for your help; I was not sure how the clutch set-up is on this unit. I will check that adjustment bolt, Maybe like you say, it wasn"t releasing the clutch all the way.
