G HEAD TORQUE
MINNIEUB
05-22-2006 06:54:02
THAT IS THE HEAD TORQUE FOR G .I TORQUED IT 208 BUT THE HEAD GASKET LEAKS.I AM WORKING ON IT FOR AN OLD MAN HE SAID HE HAS JUSTRESTORED THE TRACTOR AND MOTOR .WILL I JUST NEED TO PUT A NEW GASKET IN IT.HE BROUGHT IT TO ME SAY THE TIMING IS OUT.BUT WATER IS COMING OUT OF THJE SPARK PLUG.THANKS
Earl-IL
05-22-2006 08:55:43
 Re: G HEAD TORQUE in reply to MINNIEUB, 05-22-2006 06:54:02
Do you have the right head gasket?? Early or late "G" ?? Which head?? Earl
MINNIEUB
05-22-2006 10:59:02
 Re: G HEAD TORQUE in reply to Earl-IL, 05-22-2006 08:55:43
THE MAN THAT OWNS IT DID THE MOTOR WORK AND HE TOOK THE SERIES NUMBER TAG OFF.HE JUST HAD ME TO GET IT TO RUN IT HAS RAN SEENS IN HAS BLIULT IT.IS THERE A DIFFERNCE IN GASKETS
DSK
05-22-2006 07:15:46
208 is the proper torque for the G head. Do not overtighten, if 208 isn't sealing it, there's other problems. Overtightening will just cause cracks in the block. Sounds like you might have a crack some where if you're getting water out of the spark plug hole. (likely the head). Slide the head back off and have a look, if it's leaking that much the crack might not be that hard to find. Was the head & block surfaced? If not, at least have the head surfaced. If there is a ridge on the block surface from the old gasket,it will need to be surfaced also. Good Luck.
JLG
05-22-2006 15:51:39
 Re: G HEAD TORQUE in reply to DSK, 05-22-2006 07:15:46
If you do pull the head and check for cracks, I'd look between the intake and exhaust valves. I had the same trouble on my 1950 G. The cylinder would have a little water in it after sitting a week. I had the head checked out and thats where they found my crack. About an inch above it you could see where it had cracked and been welded before. So I bought another head, and it turned out to be cracked in the same spot! I'd be interested to know if your's is cracked there too. Maybe thats a weak spot? or maybe just a coincedence.
