HELP! JD 520 Loader
SETX
05-22-2006 05:39:59
I have a JD 5205 4x4 with a 520 loader. The loader will not raise. Bucket will rotate and it will lower but not lift. There is tension in joystick for loader lower and both bucket positions but not on lift, its slack. All hoses are connected, no leaks, plenty of fluid. All other hydraulics and tractor work fine.
Mike M
05-22-2006 07:07:13
 Re: HELP! JD 520 Loader in reply to SETX, 05-22-2006 05:39:59
Is your linkage or cable or whatever they use to operate the hyd. valve actually moving the valve ?
SETX
05-22-2006 07:25:51
 Re: HELP! JD 520 Loader in reply to Mike M, 05-22-2006 07:07:13
It"s located in an enclosed column. I"ll tear into it and check. Thats how it feels, like possible the linkage is disconnected.
