4320 JD PTO clutch valve
J. N.
05-21-2006 18:46:50
I changed all O-rings and the seal on the PTO clutch valve and it still seeps around the seal. Is the valve wore out to where I need to replace it.
matthies
05-22-2006 05:22:49
 Re: 4320 JD PTO clutch valve in reply to J. N., 05-21-2006 18:46:50
Bite the bullet, spend the $600, and make sure you adjust it so the shaft bottoms out. After adjusting check to see that the pto pistons are stiff and not quivering, when engaged.
