Head gasket cost?
jc37A
05-21-2006 12:58:20
I just priced a new head gasket for my 37A from John Deere and I hope a mistake was made. Looked up part#A404R and the price listed was $92.40. Is that right? Are there other sources that may be less? Thanks for any help. This site has been invaluable to me....Thank you!
jas
05-22-2006 13:59:07
 Re: Head gasket cost? in reply to jc37A, 05-21-2006 12:58:20
Yeah That's probably about right. Did it on my 39 a few years back. Even though mine is styled, it still is the same powerplant as yours. I think the motor changed in '40. And those are probably cheaper. I just put one in my 48D from deere about 25 bucks or so. go figure!!
DSK
05-21-2006 19:44:47
Seems odd the A head gasket would be that expensive, I bought one for my 70 on May 6, payed $62.83. Maybe the old supply ran out and they're selling a gasket from a new supplier with the expected price increase.
IvaninMich
05-21-2006 18:53:20
If you are interested I might have a set of gaskets that fit an A. I have 2 sets in Deere boxes but one is missing the head gasket ,valve cover gasket and the gasket that goes between the block and tran. housing. I can get the part number for you tomorrow if you want me to. Ivan
johns48b
05-21-2006 18:06:54
i once priced a valve cover gasket and an oil pan gasket for an off brand tractor and found out it was cheaper to buy the whole set of gaskets. you might price the whole set and see.
jc37A
05-21-2006 17:46:45
Thanks for all the quick replies! I need to add that my A's serial# is 450432. I believe the $44 head gasket at Yesterday's Tractors is for ser.#'s 488000 and up. I wonder what changed as far as the heads are concerned? Anyway, I'll check with the local parts stores for some Fel-pro sets and if that doesn't pan, I'll call Lubbock Gasket Co. Thanks again for everything!
J.C.
Comer, GA
Steve Crum
05-21-2006 17:32:37
90 bucks sounds about right for the head gasket alone, A fella I work with pulls a hot unstyled A and he said a Deere gasket is the only one he can find that will hold. He said it was 90 bucks plus tax. He's going to bring in one of his old ones for me to look at, as I might start making these in soft copper when I get the new plasma system online.
Glen in TX
05-21-2006 15:38:21
Many sell the Felpro engine gasket set for the A for about $120 to $150.
Mike M
05-21-2006 14:36:20
I don't have my books near me to double check,but is it possible that number is for a complete set for the head and block replacement ? Alot of tractors have head only sets listed in the parts book but they are sometimes more hidden. You can always get one from Lubbock Gaskets in TX. They custom make them for the pullers,just send them an old one for a pattern.
F-I-T
05-21-2006 14:50:50
 Re: Head gasket cost? in reply to Mike M, 05-21-2006 14:36:20
Nope that 's the single piece price. The set number/price on PDParts.com is:
Part Number: RE524131 Replaces Part:AA4283R Part Price: 201.25 USD
Single head gasket info I see is: Part Number: R520641 Replaces Part:A404R Part Price: 96.60 USD Description: GASKET, CYLINDER HEAD Mine always shows a couple bucks more as it varies by the particular dealer.
Frank
Mike M
05-21-2006 19:29:16
 Re: Head gasket cost? in reply to F-I-T, 05-21-2006 14:50:50
Holy Cow ! That stuff has really jumped up in price !!!
The last Deere I had the head off of was a 720 D but it was 2 or 3 years ago ? And I didn't think that set was too bad of price,but I didn't like those copper washers very well.
P Browning
05-21-2006 14:32:42
Look over at the Yesterdays Tractors Parts Store (at this website) they have head gasket for your A listed at $44.80 or some number close to that. (PatB)
DickD
05-21-2006 13:47:58
I'm sure you can find a cheaper one on the aftermarket, but would it be worth tearing the tractor down to replace the cheaper one when it fails---especially if you have painted and finished the tractor? I would use the one from Deere.
Drew
05-21-2006 15:01:02
 Re: Head gasket cost? in reply to DickD, 05-21-2006 13:47:58
Go to an autoparts store and have them look up a Fel-Pro gasket. It will be a lot cheaper, and as far as quality, IT IS THE SAME EXACT PART that Deere sells. The last head gasket I saw in a Deere pkg was a Fel-Pro with the exact same number as the one at the autoparts store, but cost 3x as much.
