6030 jd rear wieght
tracyB
05-21-2006 07:51:20
Pulling harrow 24 ft spinning like crazy with 18.4 38 tires cane tred
John Jenkins
05-22-2006 16:28:14
 Re: 6030 jd rear wieght in reply to tracyB , 05-21-2006 07:51:20
We�ve got a couple of 2-post 6030s w/duals. One has 20.8x38s and the other has 18.4x38s. They both have the cast wheels inside and out and the tires are full of water. Under a heavy load, the 18.4 x38s spin a bit but not too bad. It�s not very bad with the bigger tires. Do you have cast centers inside and out? If not, maybe add some wheel weights.
buickanddeere
05-21-2006 12:31:39
Tire pressure, single or duals, radial or bias, type of soil, any existing ballast?
Glen in TX
05-21-2006 09:17:16
What are you looking for? Get some cast iron weights or put water w/antifreeze in the tires. Can stack several weights on outside of hubs also and one or so on inside of the R41030 weights (520 lbs.) made for 38" wheels. Those were used on a 4520, 4620, 5020, & 6030 with 38" wheels. The T21689 outer weight (115 lbs.) and R35780 inner weight (285 lbs.) were only made for 32 & 34" wheels. The R49630 inner weight (1600 lbs.) only made for 32" wheels. Duals might be better too. The weighting I mentioned before on a 6030 was for one with 30.5-32" tires. Different rear weights for the 38" tires. Link
