4010 engine response to throttle lever
Corky
05-20-2006 22:03:18
JD 4010 has new carb. Engine response does not correspond to throttle lever movement. What should I look at to fix problem?
Glen in TX
05-21-2006 09:31:33
 Re: 4010 engine response to throttle lever in reply to Corky, 05-20-2006 22:03:18
Take the dash panel off and the switch panel off under dash and you'll be able to see the linkage and find the problem. The linkage wears out after 40+ years. Bushings in throttle tube, holes for linkage rods and linkage rods wear out. Can go to JD parts site and see a breakdown of it by looking at parts book page and entering model number, 4010. You'll have to register with a local dealer to be able to price parts online there.
Jim in AK
05-21-2006 09:13:34
Do you get the same problem with the foot throttle?
Jim
Corky
05-21-2006 09:23:10
 Re: 4010 engine response to throttle lever in reply to Jim in AK, 05-21-2006 09:13:34
The foot throttle doesn't seem to do anything. Right now it is stuck down. The foot throttle is very hard to move.
msb
05-21-2006 11:55:29
 Re: 4010 engine response to throttle lever in reply to Corky, 05-21-2006 09:23:10
Foot pedal is your poblem the hand and foot throttle work together and seperately.Kind of had to explain.Just remove the kick panel and free everything up(especially the foot pedal) using some good penetrating oil.
