500A ELECTRICAL PROBLEM
JAGYZF1RS
05-20-2006 20:30:32
I have 500 series A TLB that I bought last fall. Th electrical system seems to have a problem and I could use some help. This is a 24-Volt system with 2 batteries in series. What is the easiest way to test the alternator? What should the voltage be on the batteries when the machine is running (to see if it�s charging)? Should the voltage on the batteries drop off during start up and if yes how much? I just put new batteries in the machine so maybe the problem is solved, but I�d like to know more about this 24 volt system in case it has more problems and for future reference.
Bob
05-21-2006 18:54:26
 Re: 500A ELECTRICAL PROBLEM in reply to JAGYZF1RS, 05-20-2006 20:30:32
The batteries should come up to around 29 - 29.5 Volts while it's running and charging.
Bob
05-21-2006 18:53:52
JAGYZF1RS
05-22-2006 07:20:29
 Re: 500A ELECTRICAL PROBLEM in reply to Bob, 05-21-2006 18:53:52
I take it this would be across both batteries? This has 2 - 12 volt batteries in series to get to 24 volts.
Bob
05-22-2006 20:26:57
 Re: 500A ELECTRICAL PROBLEM in reply to JAGYZF1RS, 05-22-2006 07:20:29
Exactly.
