1020 wheel removal questions
Ed in Ohio
05-20-2006 10:47:18
Hello all,
I'm new to the world of tractor maintenance, having just purchased a JD 1020 a few months ago. I want to remove the front wheels in order to replace the tires. I've removed the six lug bolts holding the wheel to the hub, but the wheel refuses to come off the hub (I've only used a rubber mallet thus far). Do I have to remove the outer hub to remove the wheel?
Thanks,
Ed
Handsome Jim
05-20-2006 14:38:22
 Re: 1020 wheel removal questions in reply to Ed in Ohio, 05-20-2006 10:47:18
Ed, If it is the front wheel, all you should need to do is take the lug nuts or bolts off. Probably needs a little more persuasion. Run the lug bolts part of the way back in so the tire doesn't go flying and hit the TIRE with something a little more substantial than what you're using now. But don't get carried away.HJ
Ed in Ohio
05-22-2006 20:12:08
 Re: 1020 wheel removal questions in reply to Handsome Jim, 05-20-2006 14:38:22
Thanks, Jim. I ended up using a block of wood and a sledgehammer, hitting on the inside of the wheel next to the hub. The right front wheel required about 10 substantial hits. The left front needed only 3 hits.
I got Kelly-Springfield three-rib 7.5-15 tires for $35 each (closeouts). If anyone is local to the Springfield, OH area and needs that size, Grismer Tire has two of that size left.
Ed
