3010 hyd problem
hairpuller
05-20-2006 05:55:49
my question is, what is the three holes in the transmission case behind the filter relief for , i want to know purpose of each hole, and direction of flow thanks
HTR
05-21-2006 04:20:14
 Re: 3010 hyd problem in reply to hairpuller, 05-20-2006 05:55:49
One comes from the transmission pump, one goes to the transmission filter. The third goes to sump, if the filter is plugged, and the relief valve opens. If your 3010 has the third hole, to sump, it was drilled and the new style valve was added at dealer level.
hairpuller
05-22-2006 06:05:55
 Re: 3010 hyd problem in reply to HTR, 05-21-2006 04:20:14
The valve housing on this tractor has 2 valves in it, is this the new style? i have what i think is transmission pump oil leaving that valve housing thru the return line from steering and scv control box, just can't think that is right do you know thanks
