435 Baler tieing problems
jswintx
05-18-2006 19:56:22
I recently bought a John Deere 435 baler. After replacing some bearings, I started baling and it makes a good bale EXCEPT it does not make a tight bale. Sometimes the string barely stays on. I've only baled squares bales and I have an operators manual for the 435. I figure it's probably an adjustment, but where and what. Any help on what to do or what to look for. Oh, I'm using a J.D.2950 to pull it. Thanks
Tx Jim
05-19-2006 03:19:53
 Re: 435 Baler tieing problems in reply to jswintx, 05-18-2006 19:56:22
On the RH side of baler,there'a pressure gauge. How close to red area is needle while bale is being formed? The valve that controls pressure is under door that is across front of baler,turning CW increases pressure. If tight bale can't be attained the valve or one of the pressure cylinders is faulty. Tightness of bale and tighness of twine go hand in hand. Tx Jim
