425 lawn tractor won't turn over
will neeb
05-18-2006 14:07:48
I replaced gasket on timing cover of my 425 AWS and it now won't turn over. Wire to the solenoid is GROUNDED somewhere. All works if I remove the solenoid wire and hotwire it. I cannot find obvious short along the wire nor visible damage to board. Is this an ignition module or relay issue? Is there somewhere with schematics, (Dealer had none)?
Fern(Mi)
05-18-2006 16:26:43
 Re: 425 lawn tractor won't turn over in reply to will neeb, 05-18-2006 14:07:48
Every once in a while I forget about the safety switches. My unfamiliar with a 425(?). Does your machine have one or two or three of these? I forget about the cussed things every Spring. Fernan
willneeb
05-19-2006 07:17:53
 Re: 425 lawn tractor won't turn over in reply to Fern(Mi), 05-18-2006 16:26:43
I"ve isolated it to the circuit board or switch.
