Coolant in a Diesel 4020
Mike's 66
05-18-2006 13:08:52
I've got a 4020 Diesel that has a leaky radiator. Been keeping an eye on it, and make sure I don't run it hot, but I haven't had a chance to pull the radiator yet. My question is, do I need to run proper coolant in it for the meantime, until I get a chance to get the radiator out? Or can I run water in it, for the next month or so, until I get a chance to yank the radiator? Tractor only sees light work, about 5 hours a week. I've read the post about sleeve cavitation and I am apprehensive now to run it on just water.
Mike
Mike M
05-19-2006 09:53:02
 Re: Coolant in a Diesel 4020 in reply to Mike's 66, 05-18-2006 13:08:52
Put a big can of Bar's leak in it and it just may stop it up until later. "if later ever comes" LOL I had a real big leak in our generator radiator last power outage and that Bar's leak stopped it up.
R. John Johnson
05-19-2006 07:31:29
One thing you might try as a stop gap measure to limit your coolant loss, is to partially open the radiator cap. This will not let the system pressurize. This will slightly reduce the cooling capacity of the system, but without pressure the rate of coolant loss might be reduced.
John
K.B.-826
05-18-2006 16:53:16
Use distilled water for peace of mind. About $1 per gallon at the grocery store. It's the minerals and sediment in regular tap water that do the most harm. In a pinch, regular tap water shouldn't hurt, but I wouldn't make a habit out of it.
MSM
05-18-2006 13:24:32
For the short period of time you mentioned water should't hurt it.You could always add some Napa or Deere coolant conditioner to the water just for piece of mind.
