4020 Electrical (thought it was a starter) problem
Paul Mellen
05-18-2006 11:26:09
When starting tractor, starter remained cranking until I could remove the battery cable. Had the started & cylinoid (sp?) tested and tested O/K. Was told it was most likely the starter switch, replaced switch and when I reassembled I had the same problem. This is a 1966 JD4020 Diesel 24V system. Any ideas where I should look next?
Thanks
Paul Mellen
Tx Jim
05-19-2006 03:38:00
 Re: 4020 Electrical (thought it was a starter) pro in reply to Paul Mellen, 05-18-2006 11:26:09
Paul,the copper disk and lugs in the solenoid switch are probably pitted causing starter to stay engaged. Bench testing under no load is not the same heat build-up as installed on tractor so disk isn't as inclined to stick. Tx Jim
msb
05-19-2006 08:19:40
 Re: 4020 Electrical (thought it was a starter) pro in reply to Tx Jim, 05-19-2006 03:38:00
I agree with Jim.Replace the solenoid and be done with the problem.
Chris Kendall
05-18-2006 16:18:00
I have a 1966 4020 with 24 volts that was doing the same thing for years I had trouble with it. The starter would keep running until it pulled the batteries down. I eventually figured out that it wasn't wired up properly. Also the batteries must be equally charged or that could keep the starter from releasing. I got the JD Service Manual and wired the tractor myself accordingly and put two new batteries on it. That was 4 years ago this July and it hasn't failed yet(still have the same two batteries in it)
