Hard fast spark plug identification
Deerely B Parte
05-18-2006 09:11:49
I recently replaced the plugs in my JD B and red Cub with Autolite 388's; on the assurance from the auto parts dealer that that was the correct plug for both those tractors. It brought both machines to the top of their game, and both had a long way to go in that arena. Have since seen that the A/L 388 is a "resistor" plug and not recommended for a magneto tractor. The A/L 378 was, however, and I have tried to find them but cannot. Can someone post a GOOD Autolite number for a hot plug which is non-resistance so that I can go to the autoparts and give them a hard & fast order. Dealing with them re "crossover" numbers is like a Chinese fire drill; never get the same answer twice. Thx in advance. J Howard
Nancy Howell
05-18-2006 12:20:05
 Re: Hard fast spark plug identification in reply to Deerely B Parted, 05-18-2006 09:11:49
I've used both the Autolite 388 and the Champion D23. Both work the same in my '48 A, but the Champions put a real hurt on my wallet. They run $4.50 each, where the Autolites run about $1.25.
Mike M
05-18-2006 10:03:30
I have ran the 388 plugs for many many years and never had a problem. So if that's all you can find and they run good I'd just leave them in there. I think the problems spoken of may of occured on engines ran 24/7 under heavy loads ? I doubt any gas engines see this use today.
Glen in TX
05-18-2006 09:32:52
Try finding a Autolite 3116 extended tip type but it still isn't the hottest and = Champion D18Y. The Autolite 378 will only be found NOS by spark plug advertisers that specialize in selling the older ones or the old take apart plugs also. No chain stores are going to get those plugs and only a older parts store might have some on the shelf yet NOS. Autolite 378 = Champion D23 or AC C88L. The C88L AC may no longer be available either? Several spark plug companies have discontinued many of the non resistor spark plugs because they didn't meet their minimum sales quota so NLA. There are several foreign made plugs available in non resistor types for 14mm or 18mm for LPG and natural gas fuels but not any of those hot enough to replace the 18mm or 7/8-18 in our gasoline JD 2 cylinders. You can run 388 or 386 but just shortening the life of your magneto ignition and looking at a no warranty problem down the road...
Ben.So.Tex.
05-18-2006 11:22:07
 Re: Hard fast spark plug identification in reply to Glen in TX, 05-18-2006 09:32:52
Glen I have 386 in All my John Deer's My 720LP's and 730LP are used for field and are not Mag...
My concern is the shorthening of life on my mag tractors which are show and fun stuff.
I have had good luck with the 386,but am willing to change them out to save the life of the mag tractors
Do you recomend that it be best that I use D16 or D21 in my mag tractors?
Can I leave the 386 in the lp's are should I change them also.
Thank Ben
Glen in TX
05-18-2006 16:28:32
 Re: Hard fast spark plug identification in reply to Ben.So.Tex., 05-18-2006 11:22:07
Ben, The Champion D21 has been recommended in the Champion catalogs for all 2 cyld. JDs gas and LP using the 18mm plug since the switch to unleaded years ago. The last I ran a working LP 730 ran the D16 with no problems. Years ago butane we ran the D14 but the LP propane you get today is different so probably be okay with the D16 or D21 in the LPs. For gasoline tractors you can run the hotter D23 but be aware the wire end may not clear the spark plug cover because the newer D23 is longer now. The 386 will be fine in the LP with battery dist. ignition and = a Champ RD16. Champion D23 = AC C88L = Autolite 378
Champion D21 = AC C88 = Autolite 377
Champion D16 = AC C87 = Autolite 376 = Nippodenso M14,
Champion RD16 = Autolite 386 (resistor types)
Run what works for you or what you want but bring a mag back to me whining and complaining after running carbon core wires and cheapest resistor plugs and there will be NO warranty. No one makes a quality magneto coil these days that can stand industrial usage and the companies that make them just don't care just like the spark plug companies but they will sell you more new ones of the same poor throw away quality.
