Changing Tread Width
Frank, Tx
05-17-2006 20:06:54
Dumb question. My 52 B has cast rear wheels that are in "dished out" position with the hub clamps on the inside next to the axle housings. The cast wheels are attached to the hub/clamp with six bolts. It appears the wheels can be unbolted from the hubs and swapped side to side without removing the hubs/clamps from the axle splines. Am I correct? Sure don't want to pull the hubs off the splined axles to if I don't need to.
kirk in tx
05-18-2006 04:30:36
 Re: Changing Tread Width in reply to Frank, Tx, 05-17-2006 20:06:54
Yes you can swap them. It will change the direction of the lugs on the tread.
WHY...
05-18-2006 10:42:49
 Re: Changing Tread Width in reply to kirk in tx, 05-18-2006 04:30:36
will it change the tread direction? If you flip the wheel from one side to the other but reverse the dish of the wheel, the tread remains in the same direction.
