Glen, Duane on mag cont.
jas
05-17-2006 16:30:57
Ok Guys, I got a chance to go back and work on that 38 D with the timing/backward starting problem. First, I hooked up a timing light and fired it up. Then I turned the mag to get 25 to 30 degrees of running timing. The closest I got was 30. This with the magneto all the way turned forward. Then I shut off the tractor and checked my start timing. Looks like it's a good 5 degrees atdc. If desired is 3 to 4 degrees btdc then I guess I am 8 degrees too late. How do you change this? I pulled the mag. Checked under the cap for cracks, carbon traces, the safety washer and all looks ok. Also checked the drive coupler in gov for horizontal -looks good too. The drive on the mag says 35 degrees. also there is an L and an R on the housing above the drive. I wanted to take a picture of this stuff but my wife has the digital camera at school. If a picture helps, I will get one tomorrow. If the start timing adjustment is under the drive, how do you remove the drive. It doesn't seem like there is any way to hold the shaft from turning. It doesn't look like the nut has been loosened in years. Also the shaft feels good up and down but the drive and the "bell" behind it feel loose. I hope this makes at least some sense as it is hard to describe in written words. Can you guys tell me which way to go from here? Thanks
Mike M
05-18-2006 05:38:57
 Re: Glen, Duane on mag cont. in reply to jas, 05-17-2006 16:30:57
I don't think you want any engines starting timing BTDC as that can cause kickback. I'd leave it at the 5* ATDC
jas
05-17-2006 18:22:11
Yes it is the ES CD mag. So what do you do? Come up with a happy medium between start and run timing? Do you take it apart with an impact? Or how do you hold it from spinning? Thanks
Glen in TX
05-17-2006 21:37:36
 Re: Glen, Duane on mag cont. in reply to jas, 05-17-2006 18:22:11
I have couple of special drive lug wrenches to hold the impulse cup but you could try holding it with a cresent wrench while taking nut loose. Being 5 degrees off also isn't the end of the world if it's still running and starting okay. Nice to have it exact but being 1-3 degrees in range is close enough most times and some engines seem to like timing a bit different too. After you get the nut off the drive cup should just pull straight off. The E/S uses a coiled spring instead of the flat wound type like Wicos. Check the impulse plate screwed to mag to make sure the roller isn't worn out or bent to one side some. Trip weights should not be worn too much either on inside. When putting back together oil the spring and use some light grease on it too. Spring should have a felt inside to hold oil. Oil trip pawls also.
Glen in TX
05-17-2006 17:49:23
You had E/S CD mag right? No adjustments on impluse lag angle on it. All you can do is take apart the impulse and inspect for wear in parts. A CD mag that hasn't been apart in years usually needs to be torn down and have bearings regreased anyway. They are a thrust type E15 magneto bearing and may also require shimming some to only allow .001"-.002" end play. Something you can do is set points at a different setting to change the timing some but too much one way or the other and you won't have a hot spark anymore.
Moore-D
05-18-2006 04:06:50
 Re: Glen, Duane on mag cont. in reply to Glen in TX, 05-17-2006 17:49:23
Glen:
Do you have, or know of anyplace to get parts for the E/S CD mag? I need a rotor and cap for sure, maybe more parts, I haven't torn it down yet. It still works but it is sometimes hard to start and I suspect the mag. '46 Model D by the way.
Thanks for any leads
Moore-D
Glen in TX
05-18-2006 08:53:48
 Re: Glen, Duane on mag cont. in reply to Moore-D, 05-18-2006 04:06:50
Moore-D, You may have other problems besides just the mag? Does it have a good hot blue spark at plugs? Are you using metallic core wires and non resistor spark plugs? Have you tried retiming the engine or checking timing of mag and camshaft? Could be carburetor troubles also? I don't have any extra caps or rotors right now for CD but do have some other parts for them. Those aren't items you are just going to find new on the shelf since they haven't been made in 50 years or so. Some of us have new gaskets, rewound coils, replacement condensers and contacts to rebuild old points set but other parts would only be used or rare NOS. Try cleaning the carbon from brushes off the rotor disc with an eraser. Clean the carbon out of the cap and inspect brushes also. 2 different brush sizes were used on the CD mag over the years and those are available. CD caps are seldom cracked but cracks can be fixed with epoxy. Clean and set the points for the CD at .014 - .016" gap. The condenser could be leaking and bad and/or coil weak with insulation breaking down from old age. The coils can be tested for breakdown, firing test, and leaks on a special coil tester for that purpose. The wires off coil and condenser inside with old varnished cambric insulation can leak and short things out also and those can be sleeved with shrink tubing to insulate. Most CD mags just need a good cleaning and reinsulating or condenser but some are going to have weak coils after that many years. A magnet recharge on those is beneficial also. The magnet does not have to be removed to recharge it so don't be trying to take it off. We remove the impulse coupling when recharging them but not always the magnet on the CD. Seen more CD mags ruined by someone trying to remove the magnet and breaking the housing or cracking magnet. The CD is not complicated but can be ruined fast by the novice wanna be repair person.
