3010 miss/loss of power
Crude K
05-17-2006 06:52:35
A friend has a 3010 gas that has developed a miss. He has replaced the points, cond, plugs, solid core wires and done a compression check. All cyl's are about 100#'s. Timing is right on. All valves move up and down like normal. Under any load it seems to drop a cyl and has almost no power. On a small incline it can barely pull itself. At idle you can barely detect any miss. A local mechanic thinks its internal like a problem with a piston. Any and all help is appreciated.
larrystn
05-17-2006 17:03:06
 Re: 3010 miss/loss of power in reply to Crude K, 05-17-2006 06:52:35
Highly unlikely a piston, I would check the voltage to the coil, maybe replace the coil. It would be helpful to know if this tractor just developed this problem.
Mike M
05-17-2006 07:58:22
Have you tried opening up the load adjustment screw ? Those gassers need LOTS of gas under load. Also check the intake and/or air cleaner for blockage. Maybe temporary unhook it all at the carb. and try it.
G/MAN
05-17-2006 07:32:32
How about the coil?
