730 gas tank
SupC
05-16-2006 19:02:41
Hi, I don't know much about John Deere's , but may restore one for a friend, I haven't seen it, but he says the fuel tank has some rust through. Does anyone sell an aftermarket tank for it, or can a good used one be found? Thanks
johns48b
05-17-2006 04:32:27
 Re: 730 gas tank in reply to SupC, 05-16-2006 19:02:41
this may be a little later model for this guy to have, but try him any way. marlyn smith in ia at 712-489-2570. he's s nice guy to deal with. tell him john t in n al says hi
tyhoe
05-17-2006 20:42:56
 Re: 730 gas tank in reply to johns48b, 05-17-2006 04:32:27
Remove the tank. remove the sending unit and all pit cock. tape over all holes. put rocks, sockets or piece of chain in the tank. then roll it around or some have straped to the wheel of another tractor and driven it around,( slowly). Remove the the contents of the tank. Then rinse with mek or like. Then go to your local parts store ( ie napa ) they should have a can of fuel tank sealer. pour this into the tank roll it around ( insure all areas are coated. remove excess (let it drain out) then let dry for about 24 to 48 hours reinstall and all should be well. I did this to my 630 tank. No more rust. Worked great.
SupC
05-20-2006 19:15:35
 Re: 730 gas tank in reply to tyhoe, 05-17-2006 20:42:56
Hi,Thanks for the replies, and I will try to get in touch with the guy that might have one. I don't think sealing will fix this one if it's as bad as he says it is, he says it's rotten on the bottom. I have used the sealer before and had some luck with it, I made a machine that will hold tanks and turn them , and is geared down very slow, it works good, you just need to put in behind your barn or away from where you are, cause it sure is loud, but will shine a tank up like new. Thanks,Willie
