G top ring groove problem WMW??
Will P
05-14-2006 18:58:28
Took my 51G apart today to see how much wear I had in the cylinders. And I found aluminum pistons in it. I was told it had M&W in it. Well they are .090 over aluminum and have a part number cast inside of A1241 and after that is WMW. Who is WMW?
Now the other problem is the top ring groove measures .280 for the .25 ring on both pistons. All the other rings are tight. I don"t think it is supose to have .030 play in the rings. Who can I get rings from? I know Deere doesn"t have anything over .045 Can I get 5/16" rings in 6.215 diameter? I can cut the ring grooves no problem. #1 cylinder has about .005 wear in the cylinder and #2 has nothing. It was rebuilt in the early 70"s and didn"t have any power and was pawned off on 3 different owners until I got it. They put the pistons in upside down and put an A carb on it. It had no power until I fixed that by flipping the pistons over. But it has bad blowby so I took it apart when the fanshaft started to go.
Thanks in advance.
Will P
Earl-IL
05-15-2006 08:55:24
 Re: G top ring groove problem WMW?? in reply to Will P, 05-14-2006 18:58:28
Will P, Your pistons are White Machine Works. Later became Gould Clevite. They take a 2C7842+ .090 Hastings ring set. You can call Hastings and order direct the phone number is 616-945-2491.Otto is a good choice as the previous post. He might suggest to run a .187 & .125 ring in the top groove to correct the piston wear.Hasting made a .030 top groove spacer but I don't think they are available anymore. Two rings in the top groove will seal comp better than one wide ring . We use them in puller "G"s when we step the compression up. Earl In Illinois
Will P
05-15-2006 19:59:39
 Re: G top ring groove problem WMW?? in reply to Earl-IL, 05-15-2006 08:55:24
Earl, what can I expect for HP with these pistons. What is the compresion ratio with these? Looking at the roller rockers from Murphys Motor Sservice. Any opinion???? Want it to work the field and pull alittle. Has a cold manifold, no markings and don't know who made it. #51 carb and stock cam. Want to do a valve job and clean the ports up.
Thanks!!!!!
Hayfarmer
01-22-2007 18:09:17
 Re: Do you prefer a 51 MT or a 58 420W in reply to Dan V, 01-22-2007 16:13:10
I have a 51 MT, not wide front, and a 430(420 with face lift) I prefer the 430 though I use both. 430 or 420 has more power, 420 hs standard 3 point,not a modified lift, 420 has more hydraulic power. you can get on and off the 420 without a ladder and/or falling on your face. On the other hand the mt is higher off the ground. I would think the MT with wide front would be more "rare" than the 420. Guess it depends upon what you want to do with it. Use it or show it. For a user I would pick the 420.
Will P
05-15-2006 19:14:37
 Re: G top ring groove problem WMW?? in reply to 1eyedwillie1, 05-15-2006 05:55:46
Sorry, I meant it as what these guys have said. When the piston comes up and compresses the mix. The eye opening in the piston is not lined up with the plug. The plug fires against the piston, and not in the chamber. Making it a dog. After flipping the pistons over, by pulling the rod caps and rolling the piston 180 in the bore. I had this G out with a tandum 10 foot disk pulling it in 4 th gear with ease. But it has blowby. The breather smokes bad. And the fanshaft was walking back and forth grinding the gears in the govenor. Time to take apart.
Will P
Will P
05-15-2006 19:14:14
Sorry, I meant it as what these guys have said. When the piston comes up and compresses the mix. The eye opening in the piston is not lined up with the plug. The plug fires against the piston, and not in the chamber. Making it a dog. After flipping the pistons over, by pulling the rod caps and rolling the piston 180 in the bore. I had this G out with a tandum 10 foot dick pulling it in 4 th gear with ease. But it has blowby. The breather smokes bad. And the fanshaft was walking back and forth grinding the gears in the govenor. Time to take apart.
Will P
Bob Collins
05-15-2006 16:59:43
1 eye, I know you are visualizing the top (closed end) of the piston as being placed on the bottom and obviously that won't work. What Will meant was the piston was rotated 180 degrees in the bore so that any piston pin offset was toward the "wrong " side of the cylinder. The offset is intended to balance the power force against the top of the piston and equalize cylinder wear, when offset the other way some power advantage is realized at the expense of wear and piston slap noise. In this case there can be spark plug blocking too unless a notch is provided.
Gerald J.
11-03-2006 20:17:28
 Re: 3010 with 35 loader?? in reply to Hayfarmer, 11-03-2006 19:36:33
third party image
3010 is closed center. Its not hard to pick off power and return. Hydraulic power is available at an elbow right at the brake pedals, return to the transmission oil cover. I like to have a flow restrictor valve to keep the loader under control. For my loader 5 gpm is plenty and I want to leave main flow for steering and brakes.
My connection manifold on my 4020 is shown at>Link
I>Link use the second port for a three point backhoe.
Gerald J.
Bob
05-15-2006 07:58:21
 Re: G top ring groove problem WMW?? in reply to Mike M, 05-15-2006 06:42:32
Another good source for rings and spacers:
