Another 12 volt conversion failing JD Model M
moveme
05-14-2006 17:57:41
Hello All, I know this question has been around for years and I have read all the posts, but still am dumbfounded with my current problem. I am installing an alternator on my little JD M. I have run wiring and not getting any power from it. I have follow the diagrams and articals you all have promoted on YTMAG to no avail.
Here is what I did: AMP meter has wire to ignition switch on one post and starter lug on other post. ignition switch ON is run directly to coil. Alternator(standard old chevy alternator) large lug to starter post. #1 to coil, #2 to large lug on alternator also. pretty simple, no power output? Also tryed Large lug on alternator to lug on amp meter and ingnition switch and starter lug wires to other post on Amp meter, the only thing this did was make amp meter stop working. Is it not turning fast enough???
Thanks Mark
moveme
05-22-2006 12:57:44
 Re: Another 12 volt conversion failing JD Model M in reply to moveme, 05-14-2006 17:57:41
Yes I failed to mention the diode I do have it ready to install. I wish it would charge so I would have a reason to install it. I just have the standard chevy truck alt. pully, I guess I need a smaller one. I did have it checked out twice as I doubt myself so it does work. Any other ideas please let me know.
Bob
05-15-2006 08:02:46
You should have an "idiot light", a resistor, or a diode in the lead from the #1 terminal on the alternator to the coil, 'cause if you do get it revved up and charging, without one of the afore mentioned components in that lead, current will feed back from the alternator's #1 terminal to the coil, causing the engine to keep running when the ignition is switched to "OFF".
Third Party Image
960
11-03-2006 19:22:12
 Re: 4450? in reply to DeerePwr1, 11-03-2006 14:13:04
Have a 4430, 40, and 50 each with 4600 to 5000 hrs. Only use the 30 where I do not spend much time in it or pull a load just not as quiet and the seat is not as nice as the other two. Here in central Illinois with good corn crop and over $3. price you won't be able to buy a clean 4800 hr. 4450 for $30,000 even if it is on the older end of the production run. If you already have a 4440 why question what you are getting with a 4450 just a newer version.
