6030 JD rear wieght
tracyB
05-14-2006 08:43:48
what amount wieght needs to be on back to keep it from spining
Glen in TX
05-14-2006 17:27:16
 Re: 6030 JD rear wieght in reply to tracyB, 05-14-2006 08:43:48
Like MSB says it depends on tire size and what you are wanting to do with it. Run with duals to take off when row cropping or just run it on flat ground for heavy tillage work? We had a 6030 with 30.5-32 radials and ran the 1600# inside weights and 7 of the 115# weights on each axle for a total of 2405# per axle and you didn't spin it often but still could. Lots of power to hold down. We had the double stack weight on front also and 14 weights for total of 1510# on front. Still wasn't enough to keep from bouncing on rough ground in 4th or 5th though. The 30.5 tires bounce worse too but not as bad with radials. If running duals to remove you may want only want inside weights and/or water in inside tires too.
MSM
05-14-2006 11:38:56
Kinda going to need some more info. Are you using it for a farm tractor,or puller,what type of soils,what are you pulling,what size tires, is the engine stock,non-turbo'd or turbo'd? You need to have some slippage, about 7-10% is optimal.
We used to have a '73 turbo'd,fuel turned up,with dual 24.5x32 radials,inside tires loaded,and 1600# wheel weights inside the inner wheel and would still spin out in sandy loam pulling a 24' disc and packer.
