4010 injection pump timing
berger
05-13-2006 19:05:55
I have a 4010 John Deere that never ran right because the cam gear that runs the oil pump and injection pump was worn. I recently overhauled it and replaced the cam. Before I overhauled it probably 200 hours I had the injection pump and injectors rebuilt. The tractor does not miss out at the higher rpm's like it use to but kind of chops around 10000. Does anybody have any advice to help me out with getting this adjusted right? It has a 4020 pump on it.
lonzo
05-16-2006 21:31:17
 Re: 4010 injection pump timing in reply to berger, 05-13-2006 19:05:55
when you up date the injecton pump on a 4010 the new timing is 8 degrees. I agree with maris on the pumps
jdemaris
05-14-2006 07:26:59
Chops at 10,000 RPM? Hopefully, you mean 1000. Overadvanced fuel timing can sometimes cause that. You say you installed a 4020 pump - not sure what you mean by that. What number pump did you install? 4020s utilized a fuel timing advance mechanism and intitial - i.e. "static" timing is set different on a 4020 as compared to a 4010. If you installed a pump with automatic advance, but set the static timing at 4010 specs, the fuel timing might be wrong. Also - what did you do with fuel delivery settings? 4010 calls for a pump roller setting of 1.959" that produces 11-13 ccs of fuel at high idle - whereas a 4020 calls for a pump roller setting of 1.974" and 16-18 ccs of fuel at high idle.
berger
05-25-2006 16:46:47
 Re: 4010 injection pump timing in reply to jdemaris, 05-14-2006 07:26:59
Theses are the numbers off of the pump... 88 1395 AR32564. The shop that rebuilt the pump said it was off of a 4020 that is the reason I mentioned it being that style.
jdemaris
05-26-2006 05:31:32
 Re: 4010 injection pump timing in reply to berger, 05-25-2006 16:46:47
The original pump (AR26372) on that tractor had its timing mark set at 123.5 degrees. The replacement pump you installed is marked at 127 degrees. So, there is a 3.5 pump degree difference - and that equals 7 degrees engine timing.
berger
05-26-2006 16:46:59
 Re: 4010 injection pump timing in reply to jdemaris, 05-26-2006 05:31:32
Thank you for the info jdemaris I appreciate it.
