4430 vs 4440
Tod In Ohio
05-13-2006 11:14:46
I am looking to buy a 4430 or a 4440. I was curious what the difference is between the two other than one is a 30 series and one is a 40 series. Is the 4440 worth the addtional money?
Thanks,
Tod
DSK
05-13-2006 13:39:29
 Re: 4430 vs 4440 in reply to Tod In Ohio, 05-13-2006 11:14:46
Deeres advirtising slogan for the 40 series was "More Horses, More Iron". This kind of says it all when comparing the 30 series to the 40"s. I owned a 4430 for 9 years, worked it hard, never had any trouble with it and traded it for a 4440 which I still use for planting, cultivating and spraying. The 4440 has a 466 cube motor versus the 404 of the 4430. If your not using the tractor for heavy tillage this is not a big deal, but I could not believe the differance the first time I drove a 4440, lots more torque rise & lugging ability. The 4440 also has a better track record in the transmission & final drives as they were quite a bit heavier than the 4430's, some which had some problems in this area. Yes, while the 4430 was a good tractor, the 4440 is worth the extra $$ any day.
garret
05-13-2006 13:04:33
Had 2 new ones of each model. Have 55 series now and an 8000. Lots of iron diff between the 30 and 40. I think the $ diff is worth it. But as you go up the line I think it is more creature comfort and electronics. Seat quality between most 30's and the 40's is worth a lot. Late 30 has the good seat. One of the best small tractors around is the 4450 especially in the mfwd. Guy s really got a lot of work done with them. Front ends are getting worn now tho. There are a lot of these tractors that have only been used for planting and culitvating and spraying and are good rigs.
Mike M
05-13-2006 17:50:12
 Re: 4430 vs 4440 in reply to garret, 05-13-2006 13:04:33
A 4450 a small tractor ? You must really be out in the wide open spaces !
Glen in TX
05-13-2006 12:29:12
Search archives with your post title for more good info...
Link
Yes, it's worth more and not the same tractor and upgrades of some sort with each one, 4440, 4450, 4455, 4760.
