HOW WILL A JD MODEL 40 ROTOTILL?
SCHAP
05-12-2006 21:11:19
HI GUYS..... IS A JD 40 GEARED LOW ENOUGH TO RUN A TILLER?
HOW ABOUT BRUSH HOGGING? I'VE HAD A FEW GUYS TELL ME THAT I WOULD BE BETTER OFF WITH LIVE PTO, TOO. THEY JUST SEEM LIKE SUCH HANDY LITTLE TRACTORS. PROBABLY NOT ENOUGH HP TO RUN A BALER, THOUGH..... RIGHT? ANY HELP IS APPRECIATED.
.....DON
jCarroll
05-17-2006 05:06:29
 Re: HOW WILL A JD MODEL 40 ROTOTILL? in reply to SCHAP, 05-12-2006 21:11:19
Rototilling -
If you are doing small plot work (gardens) you will WISH you have live PTO. Enough power for a 4' tiller, a 5' will definitely need live PTO to get through hard spots, or trashy conditiions.
Mowing -
You'll be OK IF you have an overrunning clutch on the PTO.
Brendon
05-13-2006 04:02:26
I once ran a neighbor's tiller (I think it was a 48" size) on my JD M which I am guessing is geared the same as a 40. These tractors actually have a fairly low first gear compared to a Ford 8N, Farmalls, or some other tractors of that era. My manual shows 1.6 mph at rated engine speed. For most tilling jobs, this would probably be slow enough. I also run a 4' bush hog with my M and like the other guy said, you sure want an over-running clutch to keep the mower from driving the tractor. Since the 40 has a little more power and lift capacity you could probably run a 5' without much trouble.
van robinson
05-12-2006 22:42:50
Not sure on the tilling. It will run a bush hog, as long as it is about a 5 footer. Live PTO is better, but the dead PTO will work fine too. I would recommend an overrun adapter, so if you have to stop suddenly, the bush hog won't push the tractor. Also, make sure the clutch on the bush hog is in good working order. I would not try a baler. You only got about 20 HP I think.
cjdeere
05-13-2006 21:35:54
 Re: HOW WILL A JD MODEL 40 ROTOTILL? in reply to van robinson, 05-12-2006 22:42:50
Yes it'll till and very well. My father in-law has a 40 and a 5' tiller, the old 40 does a good job with it, but the new Deere is alot easier to use with the tiller on it. Chris
