3010 steering
bean pole
05-12-2006 18:50:04
I have 3010D that leaks oil out the stem going up to steering wheel, how much pressure should go to steering valve and what does the little plastic line do that goes to pressure control valve, how do you change pressure on valve, ive already put rebuilt steering valve on but still messed up must be something else wrong.
msb
05-13-2006 07:11:02
 Re: 3010 steering in reply to bean pole, 05-12-2006 18:50:04
There is an o-ring up in the steering wheel shaft area that is a bear to change if you have big hands like me and is easily damaged if one is not careful when reinstalling the steering wheel shaft.That is where your leak is coming from.The back up washer goes behind the o-ring.The seals at the top of the shaft are only dust seals and will not hold that kind of pressure.
Bob
05-12-2006 22:33:13
The steering valve operates on full 2250 PSI system pressure. The system pressure adjustment is on the front pump.
The only plastic line I can think of is a "weep line" back to the transmission case.
