How to remove/install powershaft bushings?
Kurt_JDB
05-12-2006 15:07:53
I am trying to replace the bushings at the bottom of the transmission that the bevel gear and drive shaft for the powershaft rides in. Can anyone give me a tip on how to remove and replace these bushings? I tried banging on them a little bit but they are not moving. I am particularly concerned about getting the new ones in, as they seem rather thin.
Thanks,
Kurt
Mike M
05-12-2006 15:26:45
 Re: How to remove/install powershaft bushings? in reply to Kurt_JDB, 05-12-2006 15:07:53
I think I usually use a hack saw and cut through them. The new ones are different than the originals and you may need to drill a new oil hole in the case boss. Someone may of done it before you ? The I & T manuals tell about this.
The best way I have found to put in this type of bushings is to use a piece of all thread rod and a large washer at each end and just draw the nuts up pulling the bushings in. Just make sure they start in square. I think the front one does not go all the way in as to hold a thrust washer into place.
Kurt_JDB
05-12-2006 15:33:34
 Re: How to remove/install powershaft bushings? in reply to Mike M, 05-12-2006 15:26:45
Mike,
Thanks for the reply. The replacement bushings I got from Deere came as two bushings. The original bushing appears to be one long bushing. There is a hole drilled in the top of the boss. The original bushing has a hole that lines up. The new bushings do not have any hole. Instead, they have a spiral groove cut along the length of the bushing.
Kurt
Mike M
05-13-2006 17:56:49
 Re: How to remove/install powershaft bushings? in reply to Kurt_JDB, 05-12-2006 15:33:34
Do you have a service manual for it either a JD or an I & T ? There is a special way those bushings go in and you will need to drill a new oiling hole in the casting. Pick up a copy of that manual or borrow one and get some copies as it is explained in there.
Kurt_JDB
05-13-2006 18:10:42
 Re: How to remove/install powershaft bushings? in reply to Mike M, 05-13-2006 17:56:49
Mike,
I have both the JD and IT service manuals as well as an old motors truck and tractor manual, and a few other books. Unfortunatly, none of them address this. The way these new bushings are made however, is with an oiling groove that runs the length of the bushing in a spiral pattern. I would think it would get oil from the tranny sump along this groove. I did get the old bushing out and the new ones in using the method you suggested. The two bushings do not meet in the center. There is a 1/2 inch gap between them. I guess I could drill a hole through the boss into this gap, but I sure would like some more info.
Maybe you saw this in some service bulletin?
Thanks again,
Kurt
Mike M
05-14-2006 05:07:57
 Re: How to remove/install powershaft bushings? in reply to Kurt_JDB, 05-13-2006 18:10:42
Kurt; I'm sure I saw it in my service manuals as I have not seen any service bulletins on these old JD's. They exist I just don't have any.
If I can remember later today I can look up the info when I go over to the shop. Maybe your copies left out this page ? I'll see if I can check it out. There was a special direction and placement they wanted those bushing to go.
info found !
05-14-2006 14:21:40
 Re: How to remove/install powershaft bushings? in reply to Mike M, 05-14-2006 05:07:57
I found it in the I&T book I have on the model 50,60 tractors. Book # JD-10 page 60 at the top. The front bushing should extend forward of the bushing boss by 0.082 or approx. 3/4 of the thickness of the fibre thrust washer.The rear bushing should be flush with the rear of the bushing boss.Install bushings with the narrow end of the oil grooves toward the oil hole in the boss.Groove in front bushing should be in the 9 o'clock position when viewed from the rear and groove in the rear bushing should be in the 12 o'clock position when viewed from the rear. Before installing bushings drill a 3/8" hole through the bushing boss 1 13/32" forward of the rear face of the bushing boss.
Kurt_JDB
05-12-2006 15:10:20
I should have mentioned that the tractor is a 1951 B.
Kurt
