1935 B John Deere carburator catastrophy
Jak
05-11-2006 10:17:36
I had a guy bring me his unstyled B to tune his carburator so it would start and also run better.I got it to start fairly well but it wouldn't idle very well so I took it off and cleaned the idle passages out(full of rust and dirt).I put it all back together and installed it on the tractor and it started leaking gas so I grabbed the wrench and started to snug up the bowl a little and all the sudden the bowl fell off as well as the nut and part of the carburator stem.Up on further inspection I saw that it had been brazed up in the past.Will rebrazing it hold?I don't like this Mickey Mouse way of fixing this but where on earth would you find a carb like this?The guy he got the carb from charged him 125.00 bucks exchange for this botched up carb.He'd been better off keeping his old one I believe but I wasn't there when the deal went down.Again will it be worth much(functional)brazed?Boy I was sick when that happened,glad there wasn't any women,children or sensitive ears around when she let loose cause I was hot.Thanks Fellas,Jack(TN).
Earl -IL
05-11-2006 12:32:40
 Re: 1935 B John Deere carburator catastrophy in reply to Jak, 05-11-2006 10:17:36
Email me I can help you out. Earl- Illinois
Mike M
05-11-2006 11:58:42
If it is broken up much higher than the threaded part where as to get into the other passages then I don't think it will be a sucessful fix. I have fixed some of them broken off down low in just the threaded area. By the time you pay those who specialize in this repair you may be cheaper off to find another unbroken carb.
Kurt_JDB
05-11-2006 11:27:35
A number of the carb services can braze the stem for you. Roberts carburetor or Burry carburetor service. I brazed the one on my carb,It is a tricky job because it needs to be centered and squared to the bowl just right. The carb I had did not have the broken part of the stem with it, so I had to file the stem off flat and then braze on the end of a spark plug that had the right thread. I also had to build a number of jigs to get it right.
A rebuilt carb for that tractor can be obtained from burrey"s, but it will cost you.
Kurt
